19-08-2019, 07:57 AM
Frank, I was looking at the 5150 data sheet again and saw something that might be useful.
See 2.20.14 YCbCr data path bypass. This should put raw ADC data on the digital output, just as I did with the SAA7118. It's better (lower jitter) to get H sync from a dedicated pin than from slicing the raw digits. This is possible because you can conenct H sync to a separate pin on the 5150. Again just as I could with the 7118.
