05-11-2016, 06:59 PM
Mark, I can see what you're on about. But, there's a language complication to muddy the water!
'Saturation,' when applied to bipolar transistors, means when the collector-emitter voltage is really low and the current flow is determined by the external circuit.
'Saturation,' when applied to FETs, means when the source voltage is fairly high and the current is independent of source voltage, being mainly determined by gate bias. FET's as amplifiers are almost always operated in saturation. It's almost opposite to BJT's... When the device is driven hard 'on', and the gate is driven well positive (MOSFET's), or zero (depletion JFET's), the device is said to be operating in the linear region.
'Saturation,' when applied to valves, is when the cathode emission is just sufficient to sustain the anode current, so that increasing the anode voltage or grid voltage makes no difference - the electrons are pulled away as fast as they're emitted. It's very rare to have a valve operating intentionally like this (the only case I can think of, is a white noise generating diode). Generally, a valve is saturated because the heater voltage is too low - or the valve is old and losing emission.
Having got that out of the way, what is relevant is, how low can the anode voltage go when driven hard on? In valve terminology this is referred to as 'bottomed' and is akin to the BJT being 'saturated.' And, in the absence of data, generally for a pentode or beam tetrode, 20-40 volts is a reasonable figure to assume (not as good as a bipolar transistor at all!).
Triodes, despite being simpler with only 3 electrodes, are actually more complicated as output valves. That's because they don't have the screen grid to help maintain the current at low anode voltages. So, they are much more difficult to turn hard on, and as output valves, they are less efficient. But this thread is about DA's amplifier using the trusty EL84, so let's not complicate things!
