12-03-2013, 05:20 PM
(12-03-2013, 04:51 PM)Retired Wrote: Hi,
I too had such a morticer many years ago Lawrence just as you describe; it was cast iron construction built like a battleship and weighed about the same; the long arm must have been around 4' or 5' in length with a very large round cast iron counterbalance which used to bash against the side of the machine; the cross slides were also substantial but it certainly punched holes into thick timber with little effort; the problem was that because of the long arm it needed a lot of space so in the end had to go. Mine was very similar to this;
Vintage morticing machine.
This slipping belt clutch is evading me; I've just come out of the workshop still without success; I rigged up a pair of belt deflecting fingers as shown in the pictures making these adjustable but the belt still drives having tried these fingers in many positions. With the motor tilted the belt is very slack and I can nudge it with a stick to stop it driving but as yet I'm unable to achieve this by simply tilting the motor. I've also just tried mounting a bearing on a bracket but this too has failed. I could enjoy this project but every time I visit the garage to do any work it's very cold but at least I've managed to leave the car out all day without the car getting a soaking.
I'll stick with it but the main problem is access to watch the belt otherwise I would have this job well sorted by now. What a life; the sun is now tormenting me by blinding me through the window. Each method I try is one method less and eventually I'll have tried all the unsuccessful methods first before I succeed?
Kind regards, Col.
Hi Col, yes that's the one, almost the same as the one I had.
Good luck with the clutch.
