16-09-2020, 11:46 AM
(This post was last modified: 16-09-2020, 11:49 AM by LENINGRAD T2.)
Hi Trevor,
The EHT unit in Peto Scott and in other projection televisions functions independently as a source of high voltage. Do you agree with me that it is possible to replace it with any other high voltage source for the time of e.g. tests and start-up of the TV? By using a regulated high voltage source, it is easy to estimate at what values of this voltage MW6-2 has an acceptable brightness level and at what values it can serve as a normal CRT. I mean your tests with MW6-2.
