14-07-2019, 08:01 AM
The speaker is missing too. But I have a few old larger speakers.
https://www.radiomuseum.org/r/pye_t19dt_19.html
I was toying with the idea of adapting it to use Russian Rod Pentodes. Seeing if it would "go" simply changing LT.
ECH35 can be replaced by two, one as a pentode mixer and one as triodised pentode oscillator (also works in a heptode or octode socket).
EF39 easily replaced by 1j29b. The 1j24b maybe a lot less gain.
EBC33: Triodised 1j24b and 1N60.
EL33: 1p24b or 1j29b depending how loud you want. Or change to push-pull for about x3 power and then a mains 110 -110 transformer is good for audio.
AGC is an issue. The only way to do it is varying g2 on the amps, not g1 (25V almost no gain, 50V loads of gain) as they are inherently sharp cutoff. That would need an AGC amp.
However the LO coils/Osc will work, RF coils too. The IFTs will work, as I've tested the Rod Pentodes in a couple of unmodified battery valve sets.
The hardest things doing a multiband radio from scratch are the RF, LO and mechanics of tuning scale. IF and Audio are no bother. Layout and switching of RF & LO gets hard beyond two or three bands.
Or I can do Octal. No EL33s, but KT61 and 6V6 are available.
