27-11-2016, 07:02 PM
I fully understand Jeffrey's point of view that that a solid state solution is best approach for a phono pre-amp. However, I must abide the rule which is to use the technologies employed when the equipment was made and as the RGD 1046 was made in the late forties it has to be valves. Instills a sort of discipline you could say. The Garrard SP25 was introduced in the 1960s so we are still in the valve era, although transistors were appearing in audio equipment during that decade.
So it's Bob's valve pre-amplifier that going to be installed in the RGD, mildly modified of course.
Watch out for the use of many adaptor plates and brackets.
Geordie McBoyne.
Geordie McBoyne.
especially with magnetic pickup. Stick a ceramic cartridge if you want more authentic!
