05-06-2020, 08:28 AM
(This post was last modified: 05-06-2020, 08:34 AM by Mike Watterson.)
Those LCDs last forever and are easier to read. They are not expensive.
The OLED is more a size for a wearable. The cheap OLED have shorter life than ones in phones and deteriorate in storage. There is a reason they are really cheap! The OLED are really organic compound printable dots as an Electroluminescent material that happens to behave like a diode. Then colour is added by phosphors sometimes aided also by colour filters. The small ones use cheap packages. The LCD uses glass and decent seal with glass balls in the glue so the panels are accurately spaced.
I've used the LCD graphic panels when the 16 x2 is too limited. I think 128 x 64. Programmed in JAL using an 18F series PIC.
I've done both kinds as a serial terminal in s small hand held case with a 4 x 4 key pad, 4 coloured buttons under the display for menus and sometimes other buttons too. Keyboard scan and display drive sharing output pins.
