(23-03-2019, 12:05 PM)pwdrive Wrote: With some receivers that's not always advisable, replacing en mass is the only practical route if it takes ages to strip down a part of the receiver to gain access, replace one wax capacitor reassemble, switch on and check, dismantle, replace another wax capacitor, reassemble, switch on and check and so on...so many strip down and replacements down the line, wires can snap off, bandchange switches, coils or other vital bits can get damaged in the process.
That is exactly the situation I have found myself in on a current restoration I am doing of a 1938 KB 750. I had to remove 3 capacitors to get at another.
I made a mistake as a result, so it is imperative to take photos and draw out and label the connections of all the associated components and their surroundings if this method has to be done.
But on a DAC90A I dont think the OP should have too much of a problem with the components laid out in the tag strip.
Mike
