03-11-2016, 11:26 PM
Yes, I've certainly looked at load lines for bipolars and JFETs and MOSFETs. They're in almost every text book. But, I really don't know why. Sure, I understand what they mean, but I've *never* used them during the design process. And just to be clear, I do a lot with transistors - mostly bipolar - at low, medium and high power levels. Most of what I do is analogue. But I get by without reference to load lines. Perhaps I'm missing something? I'd welcome concrete examples of something that load lines bring to the party during semiconductor circuit design - especially if there's no other way to do it.
That EL84 datasheet has a decent number of graphs! I'm really uncomfortable with the gm varying so much in valves, given that they are supposed to be transconductance amplifiers (where gm would be fixed in an ideal world). No wonder they distort like they do
Maybe I shouldn't worry, given that gm varies over a cycle with a bipolar transistor as it's directly proportional to Ic. We ignore that when thinking about small signals, but it's clear to see on the 'scope screen with large swings. One good reason to load with a current source! Plus, there is so much gm available that NFB does a splendid job of linearising it anyway.
The shape of gm vs. Vg - is that typical, or does it vary from device to device?
I note that the graph gives gm vs. Vg, and not the gm vs. Ia that I was after, but still interesting nonetheless.
At least the Ia vs. Vg curve is nice and reassuring
Andy (DA), Andy (radioman) makes a good point about measuring the inductance of the transformer primary. I'm wondering if shorted turns might be the problem? Do you have the means to measure inductance? I'm guessing that one of those Chinese component testers would probably do the job.
