30-11-2013, 06:17 PM
It's also worth making sure that the volume control is working ok, ie: not cutting out when turning from min to max.
The approach to fault finding can vary between different folks, with battery operated transistor radios my own approach would be first to check that the battery is up to scratch (I believe you have fitted a new one) my next step would be to check the quiescent current draw from the battery to see if it's within reason.
All above being ok then I would try and ascertain which part of the receiver the fault is in ie: AF or RF then take it from there.
