So do some Philips sets! In their quest to be different, they made some valve sets which had no output transformer and a much higher impedance speaker that you can't get now,
To make matters worse, they were in the anode circuit of the O/P valve so when they went open circuit, the pentode had no Anode volts but full HT on the grid. The valve didn't last very long...
Of course, you could modify them....
Cheers,
Steve P.
P.S. The smilies work!
(15-11-2011, 05:30 PM)Joe Wrote: It sounds fine through the Roberts speaker but through the ten inch Richard Allen one it was setting my teeth on edge.
I rediscovered this post a few days ago.
Since making it I've built the 10" speaker into an amplifier and found that it does not like high frequencies which certainly exonerates the Pye.
03-11-2013, 03:35 PM (This post was last modified: 03-11-2013, 03:36 PM by standunmj.)
hi joe , i really like your pye r33, ive been trying to e mail you re same but your gone off the planet,i have an ekco u 353 here that looks remarkably like the pye, ive put it up on my forum, hope you see this as its very far down the list of your thread , best regards maitiu.
great joe, the pye factory in dundrum ,dublin , made all sorts of irish variants back in the day , i ve never come across aything like your model, most of the fenman11s for export were made in the factory, nothing left of it now , theres an enormous shopping center built on it now, hope the sound on your set is better now , regards mait.
