09-07-2011, 11:21 PM
So are you planning to die soon then Pillwencher?
Anyway, have you got a signal generator. If you have, then make sure the IF gets out OK. On these sets it is 470Khz,
Also, have you tried picking up the oscillator on another set? Tune the Pilot to around Virgin FM, 247 Metres. Or round there. The oscillator is 470kHz below this, so this is around 745 kHz on the receiving set, About 400 metres. See if you can pick this up.
Check the valve socket itself as well, as it may be the problem. They can go funny!!!
Cheers,
Steve P.
Cheers,
Steve P.
