10-01-2025, 05:36 PM
Well done with using your generator like that. No need to worry about interlace for getting the set going. If you generate 202 or 203 lines, progressive scan, 50Hz field, it will work just fine. The only thing you won't be testing is how well the sync separator is dealing with interlace.
