30-08-2019, 10:56 AM
(30-08-2019, 09:59 AM)Crackle Wrote: I didn't know that, I thought the larger the value the more effect it had on all frequencies.
Mike
https://www.youtube.com/watch?v=9EaTdc2mr34
5 amp stabilised supply
(30-08-2019, 09:59 AM)Crackle Wrote: I didn't know that, I thought the larger the value the more effect it had on all frequencies. https://www.youtube.com/watch?v=9EaTdc2mr34 Lawrence.
30-08-2019, 11:20 AM
(This post was last modified: 30-08-2019, 11:21 AM by Mike Watterson.)
(30-08-2019, 10:36 AM)boater sam Wrote:(30-08-2019, 09:59 AM)Crackle Wrote: I didn't know that, I thought the larger the value the more effect it had on all frequencies. Only the more compact ceramic capacitors using the fancy dielectrics with very high values. of K. They are also voltage and vibration sensitive. Larger size 1nF and 10nF are only limited by lead inductance. SMD are better, depending on layout. It's easy to solder SMT caps, resistors, transistors and diodes to pre-tinned track side of veroboard/stripboard. |
