28-01-2018, 12:45 PM
Have you thought of adding a fixed 10K on the low end of the volume control and see how it performs? If the volume still jumps and the RS pot is a log taper then try tacking in a linear 20K in to see how it goes. As the IF valve DC conditions are set by this component its value may be more important than a "normal" volume control.
I believe RS still has a range of 1/4" shaft switched pots, but they would not look very "period".
BTW the discussion on ultragainer and supergainer radios is here http://theradioboard.com/rb/viewtopic.php?f=3&t=3256&p=77918#p77918
