08-07-2025, 10:38 AM
(08-07-2025, 06:13 AM)BusyBee Wrote: It's a nice looking board![]()
hFe readings on Germaniums generally are very low as compared to current silicon. Modern meters often don't cope with them either. I think it's probably their very high leakage, numbers of microamps, as compared to hFe's often of twenty or less. Power transistors can be even worse.
I have an old analogue meter which tests them Ok but when I tried some with a modern digital meter I had I got no sensible readings.
All true. Also if I'm building rather than restoring I'd often use Silicon and change the bias. PNP keeps the supply rail and electrolytics the same, but NPN is no problem, same bias as for PNP silicon.
A huge issue with a germanium power stage is the thermal runaway, so can need an NTC thermistor or something, on the heatsink. Typical example. A silicon based amp can still have thermal runaway, but it's rarer.
[/email]![[Image: 7d157a4f-4f21-4d8f-8d9a-c1e845c49fe3.jpg]](https://hosting.photobucket.com/a9e03734-c956-4fae-9fe5-b64068513773/7d157a4f-4f21-4d8f-8d9a-c1e845c49fe3.jpg)
![[Image: b001b37c-fa6e-4802-9520-37171aca378b.jpg]](https://hosting.photobucket.com/a9e03734-c956-4fae-9fe5-b64068513773/b001b37c-fa6e-4802-9520-37171aca378b.jpg)
![[Image: 4cfa2772-ff8e-4708-9d4e-1d82bb0dd36e.jpg]](https://hosting.photobucket.com/a9e03734-c956-4fae-9fe5-b64068513773/4cfa2772-ff8e-4708-9d4e-1d82bb0dd36e.jpg)
![[Image: 6b6c4383-005e-41ec-be7d-058163411e12.jpg]](https://hosting.photobucket.com/a9e03734-c956-4fae-9fe5-b64068513773/6b6c4383-005e-41ec-be7d-058163411e12.jpg)
![[Image: 1b69572f-a985-4827-9134-d5ac919277ca.jpg]](https://hosting.photobucket.com/a9e03734-c956-4fae-9fe5-b64068513773/1b69572f-a985-4827-9134-d5ac919277ca.jpg)
![[Image: 562c82f5-e343-478e-9642-e2807767c13c.jpg]](https://hosting.photobucket.com/a9e03734-c956-4fae-9fe5-b64068513773/562c82f5-e343-478e-9642-e2807767c13c.jpg)
![[Image: 86829b88-f2f8-40a0-a368-ac0a919e21ce.jpg]](https://hosting.photobucket.com/a9e03734-c956-4fae-9fe5-b64068513773/86829b88-f2f8-40a0-a368-ac0a919e21ce.jpg)
![[Image: c2875699-97a3-45f9-8b74-70e394d2c0a6.jpg]](https://hosting.photobucket.com/a9e03734-c956-4fae-9fe5-b64068513773/c2875699-97a3-45f9-8b74-70e394d2c0a6.jpg)
![[Image: 1116b0b3-8de5-4eba-b045-65666df8a562.jpg]](https://hosting.photobucket.com/a9e03734-c956-4fae-9fe5-b64068513773/1116b0b3-8de5-4eba-b045-65666df8a562.jpg)
