07-10-2017, 07:11 PM
(This post was last modified: 07-10-2017, 07:12 PM by Murphyv310.)
Hi.
Further improvements made today.
Only two component changes are required in the frame stage to run 25Hz so long as a 30PL1 is fitted instead of an ECL80. Details later on.
This is 180 lines showing test card "F"
This is 240 lines showing an incorrect test card "C" with BBC2 625 lines
I could do with two full size Test Card "C" images one stating 180 lines and the other 240 lines to load into the Multistandard Aurora memory!!
Focus could be better but I'm sure my CRT G2 volts are too high.
