Hi wee bit of luck been checking transistors as quite a lot are socketed.
Applied signal from generator and triggering stable apart from vertical green line from top to bottom and a horizontal faded line scrolling in Y direction bottom to top.
See photo.
When rotating intensity knob voltage varies from 8vdc to 89vdc.
Intensity too bright cannot reduce???
Any ideas.
Cheers, John.
(12-02-2017, 04:32 PM)johnmcgivern Wrote: I agree. Craig could you please write the set up for both scopes so I can test waveforms as I am not to sure.
Are the waveforms shown 1x or 10x probe?
Tried them settings but signal was walking.
Tp924 is ok when intensity mid position around 50volts.
-75 is too low. Measures -69.4
More testing tomorrow. Ha ha
(13-02-2017, 09:58 PM)johnmcgivern Wrote: Tp924 is ok when intensity mid position around 50volts.
OK - which implies that the A half the chip and the associated transistor network for TP924 are working.
Possibility is that there is a fault in the DC restorer (diode phut, transistor phut, capacitor phut etc), or there is a problem with the HT, which is handled by the chip B half and a resistor chain.
