08-04-2019, 10:47 PM
(08-04-2019, 09:03 PM)ppppenguin Wrote: That's an unusual looking technique, with the output transformer connected between the screen and anode of the EF80.Hi Jeffrey,
thanks for putting in the google translation. I am quite surprised how well it worked. Apart from some terms like "NF" which is German for Audio Frequency (AF) google did a pretty good job.
The method I used was the method described by Joe Sousa using the 6AS6. That pentode was designed to be driven by both G1 and G3 to facilitate FM demodulation and other functions. I have another project using two 6AS6 as a switching stereo encoder. That project is built as follows:
- ECC82 #1 as audio amp for left an right channel
- ECC82 #2 for 38kc multiplex carrier generation giving two outputs with 0° and 180° phase to drive the two 6AS6
- 2x 6AS6 as multiplexers. 180° and 0° 38kc fed to G1, Audio L and R fed to G3
- PCH200 as a frequency divider /2 to generate the 19kc pilot (yes a single heptode can be used as a flip-flop)
- a third ECC82 to sum up stereo multiplex and pilot.
- a PCF82 as a free running FM modulator and output. This project can provide 250mW in the FM band.
Instead of ECC82 which have become quite expensive I used Russian double triodes 6H3п. Instead of the 6AS6 you can use a 6ж2п the Russian equivalent of the 6AS6 which can be found on Ebay for a reasonable price.
With the availability of many small FM TX modules from China certainly nobody really needs such an encoder but I had great fun building it
My main interest was to learn some new things e.g. I found out how I could use a heptode as a frequency divider and I wanted to find out if my idea of using two of the 6AS6 as linear switches would work -and it did.Here are a few images of the project:
Below is the output signal with one channel input only with a 1kc audio signal. This is the typical stereo multiplex signal curve...
Please excuse the German naming of the image files, I copied them from the German forum where I had originally posted teh project.
If anybody here is into AM Stereo (Motorola CQUAM) here is another thread on RM.org (in English) about yet another project I had built...
https://www.radiomuseum.org/forum/am_ste...lator.html
Cheers
Semir
