16-05-2015, 09:57 PM
Ooops, Thanks Mark, sorry forgot it was a chassis tranny. Better to work on anyway than an early pcb with all the problems that they had. There is a lot more space to work in too.
WD40 is not good for radio servicing, or a lot of other things too. Proper stuff is much better.
The on/off switch may self fix if it is used a few times providing that the spring is not rusted away.
The potentiometers with switch are available without too much searching or expense if all else fails, or you may be able to sort the switch out if it is carefully dismantled.
Capacitors are available from many suppliers, some may be local to you otherwise it will be mail order. Have a look on line at say Maplins and RS components catalogues, it will give you an idea of what is available. You won't find exactly the same as is in the set.
Boater Sam.
