03-05-2015, 07:44 PM
(03-05-2015, 06:11 PM)Keithstv Wrote: I can't see anything wrong with the basic circuit but I would put a 10k resistor in series with the variable as the 555 could be damaged if the pot is at minimum resistance. I always decouple pin 5, 10nF should be OK.
Is the relay turning on when power is applied? If so does it turn off after about 3 seconds?
Keith
Thanks for reading the thread Keith and for your comments.
The relay turns on the instant that I apply power and pin 3 goes high, but I've discovered that if I switch off for a couple of secs then back on again, pin 3 stays low and the relay doesn't come on until the bell push is pressed, at which point pin 3 goes high and the relay operates as it should. I wonder if the initial switch on charges up a cap, and when switched off and back on again, because the cap is charged, the 555 then behaves itself? Just clutching at straws really.
I need to revisit the combination of C1/R1 to get the time duration right, because the relay doesn't go off within a few seconds as it should.
(I added a 10nF cap to pin 5 of the IC, and I'll take your advice about adding a 10k resistor is series with the preset).
BVWS Member.
G-QRP Club Member 1339.
BVWS Member.
