15-02-2013, 09:43 AM
When I got back into radio restoration a few years back, I was glad that I'd saved a fair few Ge transistors from my childhood. I also keep a look out on eBay and similar places - a lot are massively over-priced, but there are occasional bargains to be had. And you there are no shortage of total basket-cases on eBay, and a complete radio (including postage) can be had for less money than the bare transistors in some cases.
But yes, change that electrolytic first. Then perhaps try a Si PNP in the oscillator position - it might be more reliable than the AF239 with the new capacitor. If you can find an AF12X or AF11X, then so much the better. I assume you're aware of the tin whisker issue with the latter, and how you might "fix" it?
And yes, ribbon cable is your best bet. It should be reliable enough, but you can always parallel up cores if worried. How nice to find someone that doesn't just drill a hole in the side :-)
Hope this helps,
Mark
Hope this helps,
Mark
