25-11-2012, 12:57 PM
The best program for any application is:
Its worth pointing out that the macro & step functionality of the more sophisticated packages allows you to programmatically create drawings that are so complex that to re-scale or recalculate them would be a substantial manual process prone to error.
e.g. if you look at this project - http://4hv.org/e107_plugins/forum/forum_...90019.post that I did a while ago, each of the struts is almost the same but the recesses for the copper coil make a spiral up the former - this would have been very complex to do manually, but using macros to generate the formers I could play with the number of turns, the length of the coil, diameter of the tubing used, number of vertical formers created, thickness of material etc. just by changing a number or two and pressing a button.
Having invested the time to learn the product, I now use it for everything as its does it for me - but very few people need that sort of stuff - its complete overkill for most.
To generate scales, I can see that macros would again be the way forwards for me - there are also several programs out there for scales such as Galva
Use whatever you are most comfortable and productive with...
- The one you have, and...
- ...which works for you
sıʌǝɹq ɐʇıʌ `ɐƃuol sɹɐ
ʞɔıu
ʞɔıu
