14-10-2024, 03:27 PM
Have you e-mailed Jerry ay the second link I gave... must be quite an expert ...
Gary
Gary
Decca Roller Map Display
Gary
14-10-2024, 04:46 PM
(This post was last modified: 14-10-2024, 04:46 PM by Mike Watterson.)
(14-10-2024, 09:40 AM)Radio Fixer Wrote: The map, as I understand it, was for fixed areas with the pointer that could include a pen to draw a trace of the route travelled. Very popular wuth fishng trawlers who could lift the lid and and add an X where they had found good fishing on previous occasions.This one looks too narrow for marine and doesn't look like it takes a pen. (14-10-2024, 10:02 AM)djrm Wrote: I had assumed this was an aviation device, I se the Decca system was used for both ships and aircraft too. Getting an actual map would be great, or even seeing what one looked like. D I think the marine models are much much wider. This one may be for a helicopter or plane on a regular route.
15-10-2024, 08:56 PM
(14-10-2024, 03:27 PM)Radio Fixer Wrote: Have you e-mailed Jerry ay the second link I gave... must be quite an expert ... I had a reply from Jerry but he has never seen one before like this and has no further information. I took the plunge and removed the covers and found it has two synchro-torque-receivers driving the X and Y axis' with a differential synchro transmitter for the 'track' control. 115/90 volt intended operation, I should be able to do something to drive these if I can boost the voltage from my generators. I've worked out where the connectors go but some of the internal wiring is still a mystery - Github updated with more photos.
16-10-2024, 07:38 AM
I spotted the Pic showing the rather posh leather covered box. So doubtful on the marine use, bearing in mind Mike's pertinent observaton as well.
In very nice condition and beautifully made. Gary
16-10-2024, 11:21 AM
(16-10-2024, 10:20 AM)Andy M0FYA Wrote: The reference 6B/3225 is an Air Ministry Stores Reference Number.So maybe was for an RAF helicopter.
17-10-2024, 03:39 PM
Hi Folks, I believe there is an example of this kit on display at the NELSAM museum in Sunderland
Ed |
| 4 Guest(s) |
