05-04-2024, 02:48 PM
Hi thanks to David for kindly providing me the circuit diagram and advising me what capacitors to replace before switch on I removed the chassis from the set and it has 2 issues one is the mounting posts in the cabinet is broken easy fix by gluing but unbelievable this set has has the same shocking Bodge repair by replacing the smoothing with the incorrect type and value taped up and insecure a long time ago . Is there an issue with the make of capacitors in Philips radios as 60 oldjohn featured a Philips 291U on the UKVRRR forum on Sept 18TH 2016 his set had been replaced with the correct type and value Radio Spares smoothing capacitors pictures of my set to follow kind regards Bob
What Goes UP Must Come Down
