13-12-2022, 12:30 PM
Another modification to the AM-FM switch.
The AM local oscillator is shut down when the receiver is switched to FM.
This is implemented by shorting the HT supplied to the local oscillator and screen grids of the UCH42 and UF41 valves to chassis via a 1.5Kohm resistor.
A rather crude method to kill the local oscillator but no other alternative could be found because of the limited number of function positions on the MW/LW/FM switch. An alternative is supply the local oscillator with HT from the reservoir capacitor via a 47Kohm resistor, but in practice the reduction of voltage on the sub HT rail is only a small figure.
I find the FM module is sensitive to a low temperature environment. I'll move the receiver to somewhere a bit warmer than the workshop and report back how it performs.
Geordie McBoyne.
Geordie McBoyne.
