15-02-2021, 06:03 PM
Well it sort of works, but not that I could actually use it. I tapped off the 38.15 MHz IF from my first sound trap in the vision stages by adding a loose coupled single turn, this then feeding via some co-ax to the input of the sound IF. I do not have enough signal doing this and the best I can get it also provides plenty of frame timebase noise on the audio as well. So back to the idea's board, see what I can improve on. Perhaps pick up the IF a bit sooner, or via a small cap on the anode of the first stage, and maybe put a vision trap in the sound IF.
Other thoughts are filter the audio after the demodulator. Think I need to check a few TV circuits before I do much more.
It's still fun.
Adrian
It's still fun.
Adrian
Learning as I go!
Youtube EF91 Valve
Youtube EF91 Valve
