23-10-2020, 08:14 PM
(This post was last modified: 23-10-2020, 08:15 PM by Geordie McBoyne.)
from the February 1959 Radio Constructor magazine. The "Solar Three" a miniature light operated transistor radio.
From the text:
"Apart from its fascinating ability to operate from light rays, the Solar Three adequately meets the normal requirements of a pocket transistor receiver in the personal class. It is completely self-contained, it is housed in a neat plastic case measuring 4 3/8 X 3 X 1 1/4in, and has it's own ferrite frame aerial. As mentioned above, it's output is fed to a miniature hearing aid insert.
The transistors were Ediswan make, TR1 XA103, as specified or it can consist of any similar transistor having an alpha cut-off frequency greater than 2Mc/s. OC44? TR2 and TR3 may be XB104, OC71? Greater power will be available if an XC101 is employed in the TR3 position. OC72?
Geordie McBoyne.
From the text:
Geordie McBoyne.
