22-10-2020, 05:59 PM
Hi Rob.
I've just received the Pye Radio from you and have had a look. Initially I was impressed with a good sized box and stiffening cardboard added.
Then I could see the radio was actually rather not to well supported, the extra cardboard rolled up and the paper didn't support the front and sides too well. As couriers tend to throw the boxes about the weight of the set quickly compresses the paper and rolled up cardboard.
The long and the short of it even with a board over the glass it is broken.
Its better to fill the recess in the cabinet with bubble wrap where the glass is as it helps to damp shocks, the glass was unsupported so cracked.
Another point if you are using tape on a cabinet, use low tack tape or masking tape as it is less sticky as sellotape lifts the French polish and even the veneer.
I'm not criticising what you did as I think this could be the first set you've sent but its advice for the next one.
