14-03-2019, 09:15 AM
Didn't spot the error, Nick. Thanks for pointing it out.
Bias Probes for Valve amplifiers
14-03-2019, 10:18 AM
(14-03-2019, 06:53 AM)Nick Wrote: You had a typo in your link - instead of a colon ":" you had a semi-colon ";", i.e. "https;", so the editor didn't convert it. I have now corrected that for you in the original post The link still won't work, Nick, because there is an apostrophe "'" in it that shouldn't be there (as discussed in later posts).
14-03-2019, 10:45 AM
The most common error I have seen in manually typed links is a full stop at the end.
It acts as a full stop to the link ever working.
16-03-2019, 11:02 AM
(14-03-2019, 10:18 AM)Terry Wrote:(14-03-2019, 06:53 AM)Nick Wrote: You had a typo in your link - instead of a colon ":" you had a semi-colon ";", i.e. "https;", so the editor didn't convert it. I have now corrected that for you in the original post Did you try the link? If you look, you'd have seen that I had fixed that too...
sıʌǝɹq ɐʇıʌ `ɐƃuol sɹɐ
ʞɔıu (16-03-2019, 11:02 AM)Nick Wrote:(14-03-2019, 10:18 AM)Terry Wrote:(14-03-2019, 06:53 AM)Nick Wrote: You had a typo in your link - instead of a colon ":" you had a semi-colon ";", i.e. "https;", so the editor didn't convert it. I have now corrected that for you in the original post I didn't try it because I could see the error on the screen but, as you insist: This site can’t be reached www.that%27saudio.co.uk’s server IP address could not be found. the %27 rers to the apostrophe in https://www.that'saudio.co.uk which is from post #3, which is the one you initially corrected. I think the confusion is because the link has been repeated in other, later, posts.
16-03-2019, 12:06 PM
Note my comment that I fixed it in the Original Post - not every post in the thread.
Others had already commentated on the erroneous apostropy.
ʞɔıu
16-03-2019, 03:41 PM
Sorry, Nick.
I had it fixed in my mind that the link first appeared in post #3 which, of course, was true until you corrected post #1! Apologies for my confusion. |
