07-08-2016, 10:34 AM
Jeffrey,
There is a triphase disjoncteur fitted by EDF/ERDF and only they can change the setting. There is also another unit which is sealed and again only accessible by EDF.
Out of this come the four supply cables :
Ph1
Ph2
Ph3 &
Neutral.
It would certainly be easier to just fit one 3 phase CU, I will have to find out if that is the way it is done here.
I did look on the web and the wiring systems I saw used separate CU's.
Sam,
Yes radial circuits, maximum 8 x 16 Amp outlets on one spur (outlets can be double and count as single. Cables have to be 2.5 mm. No UK type twin and earth here as the earth is not sheaved and means the cable as a whole is not double insulated which it must be.
Maximum number of cables allowed in the flexible conduit.
Now all outlets have to be earthed, although there are still plenty of old systems like ours that aren't.
All junction boxes must be accessible and not hidden under flooring etc.
Generally once the 3 phase issue is sorted the rewiring shouldn't be a problem.
I may find a French sparky and ask them how it is done. The book I have only covers monophase installation.
We could have the supply set back to monophase but having 3 phase is good as the woodwork machinery I bought is 3 phase and more powerful than the single phase versions.
Thanks for the offer on plumbing advice it is always useful to have someone else to talk over problems with.
I'm pretty good at plumbing - although it is not my favourite job.
Here in France there seems to be a preference to braze copper pipe rather than soft solder!
I think I will stick with soft soldering as it is easier.
I was surprised when I bought some fittings that they were marked 1/2" BSP, I was expecting all fittings to be metric. It seems as though this stems back to the days when the UK supplied 'the world' with plumbing fittings!
Andy
Ph1
Ph2
Ph3 &
Neutral.
Sam,
Andy
