06-03-2016, 09:23 AM
Hi.
Well we are all told the plug fuse is to protect the mains cable only. I'm somewhat sceptical about that statement as so many items have no internal protection at all.
The worry is often the mains switch if fitted, especially double pole types. Remember the Preh switches that Sony used? The many cheap rotary switches that BRC used and of course the ubiquitous 1uf 1000v cap across the mains, some of which were "before" the switch.
The scenario of course is the possibility of something breaking down, during that time a couple of amps being drawn and something catches fire, Joe public may have fitted a 13 amp or 5 amp fuse which merrily passes current till a full blown short blows the fuse.
There must be millions of electrical devices out there that are not properly protected by over rated fuses, we have the advantage here in the UK to be able to fit a fuse in the plug that is rated closer to the items requirements so although a 1 amp fuse may be still way in excess of that items current demand it has due to the aforementioned be a safer option.
