22-12-2015, 04:38 PM
2nd part of the reverse engineering exercise, a bit more complex this one, it's for the RF amp grid circuit, I haven't posted a pic of the switch as it's the same construction as that used in the RF amp anode tank circuit, the only difference is that there a two extra contacts and three extra positions.
As can be seen is basically an incremental job using a combination of series antenna capacitance tuning and normal parallel LC tuning, it took me a while to reverse engineer this one, the next will be the 4 pole 3 way lever switch, once that's been done that will be the end of the complicated bit.
All RF coils in the receiver showed continuity on ohms range when I tested them.
More to follow.
Lawrence
More to follow.
Lawrence
Anyways the corrections are listed below:
