26-08-2015, 03:50 PM
(26-08-2015, 09:30 AM)pwdrive Wrote: Trevor's covered it really regarding removing old components that have been wrapped around tags etc, a fine pair of decent quality side cutters also makes life a lot easier, I've always removed the bulk with a solder sucker then finished of with some solder wick then unravel/cut using a sharp pointed tool and fine side cutters.
I found some great wire snippers. You have to be so careful to snip only the lead and not something else. So far so good. I did have a weird problem on one soldering connection today that had me frustrated. It just wouldn't take at all. Normally it's fine but maybe I think the iron got too hot. I switched it off for a bit and started again and finally the joint seemed O.K.
I'm not under any pressure with this set at all as it's my third repair. Given it's definitely a very hard radio for me to work on, due to 15 or so years in a barn, I'm not going to be hung up if I don't succeed. I'll just give it my best shot and stay calm. However, I think there's a good chance it can be fixed up so it's a learning curve for now.
I'm aware some people like to stuff original capacitors with new ones but the originals in this case were really too blistered and degraded to bother with that. Sure, I've seen capacitors that are maybe worth re-using for originality but this set has had a fair few Winters on the Moorlands in storage.
