(30-07-2015, 08:12 AM)unrealdave Wrote: Has anyone got any tips on drawing circuit diagrams?Dave, I use Paint for everything - not that I'd stop you experimenting with anything else, of course!
I am driving myself nuts trying to use paint and get straight lines - I have a bunch of jpg's for the symbols but putting them together is going to take all day. I s there a package I could get that's cheap (or free)?
A couple of tips:
- Work at a greater magnification that the final result, it makes it much easier to see - and correct - those jagged lines (I usually use 200%)
- Draw a line but do not click out of the line drawing mode. You will see a tiny square at each end of the line as in (a).
- If you hover the cursor over one of the squares, a double headed arrow appears - click on it and drag the end of the line until it is straight: you can also adjust the line length if you wish (b).
- Something I don't use but you may find it useful is the click Gridlines on the View menu ©. Paint doesn't have a 'snap to grid' function but you might find the grid easier to follow when drawing lines.
I note that you have a jpg symbol file, which is a pity - as I explained in another thread recently, the 'p' stands for pictures - the sort you take with a camera. You should use the png format (where the 'g' stands for graphics) for your schematics to avoid the degradation caused by the jpg compression.
I've attached a symbol file I've gradually been adding to over the years which you are free to use - note that the symbols are 200% of normal size!
Finally, to prove that you can draw (lots of) straight lines using Paint, I've attached the latest revision to the Dulwich museum's RF distribution system.
