23-06-2015, 07:52 AM
Further to the above, I also found that, although the sound quality of the NG5151 is OK at mid to high volume levels, there was distortion at low volume settings. The cause turned out to be that the speaker cone was partially detached from the metal rim, probably due to the fact that the mains dropper resistor and o/p valve, both of which are horizontally mounted, are underneathe the speaker, the valve only being about 0.5" below th cone, and, especially after 55 years, rising warmth from the valve & dropper had dried out the adhesive used.
Could this only have happened in a Philips Player?? (Due to the way the amp. & dropper are installed!)
