24-07-2014, 07:41 AM
The resistance of the cable is 0.054 ohms, the bulb dissipates 55W @ 12.6V so it draws 4.37A and the cable drops 235mV, i.e. only about 2% of the total - within the limits of experimental error, this effect can probably be ignored.
14.4V is 14% higher than 12.6V. The graph you used shows that 15% over-voltage from nominal results in a current increase of about 10% (for heaters in a vacuum - remember this is not perfect as heaters tend to glow RED not white hot), i.e. the voltage drop will now be about 260mV, i.e. now only about 1.8% of total and again, can be ignored.
I wrote a calculator some years back to compute the necessary PCB track sizes to carry various currents within the constraints of set temperature rises and the various ANSI standards... Its not geared particularly to cable and doesn't compute skin effect impact, but its pretty accurate for low frequencies (e.g. DC ! ) (*)
ANSI IPC-2221A PCB Trace Width Calculator
The calculator agrees with your cable resistance of 0R054 (3m * 1mm^2 Cu) and shows that the cable will increase in temperature by about 0.2C above ambient and dissipate about 1.3W
(*) It's become a popular page in the last 10 years or so - It gets 10,000 hits a month
sıʌǝɹq ɐʇıʌ `ɐƃuol sɹɐ
ʞɔıu
ʞɔıu
