03-01-2014, 07:54 PM
(03-01-2014, 07:07 PM)Robert Darwent Wrote: I've also got this thread running on UKVRR and someone suggested that the extra valve may be due to problems sourcing the EBL31 valve usually fitted in the A22. Then I noticed in the images that the valve in position V3, where the EBL31 usually sits, is too small in diameter to be an EBL31.
I now believe Ekco, for whatever reason, substituted the EBL31 in some of the chassis for say an EBC33 and an EL33. If correct the valve line-up would have been: ECH35, EF39, EBC33, EL33, AZ31
The A22 was released just after the end of WWII and possibly valve shortages at the time forced the production of a limited number of chassis with the fifth valve. I know for certain Ekco did the same sort of thing with the AD75 round Ekco which can be found with a chassis having either a CBL31 or Pen453DD output valve and/or side-contact valve substitutes in some of the other valve positions.
Regards
That sounds very plausible Robert.
