12-11-2012, 10:55 AM
(This post was last modified: 12-11-2012, 11:26 AM by Radio Fixer.)
Well, from the Hammond chart (there is a similar one in RS component catalogs) if it is used full wave into a capacitor I/P filter then its 1:1, the best configuration with the DC components canceling out in the core (is this right?). Intuitively I think that it is, and from deep in the memory, but I cant find anything on the Web that says this from a quick look. Good this Forum, gets me brushing up on theory...
So DC can be 100mA but I wouldnt push it that far and I would like it to be under 75mA.
I'm not sure that Hammond, or anyone else, derived these ratings from calculation but suspect it was from temperature measuements; how hot their Xformers got, in the various configs?
For full wave, from a centre tapped Xformer into a resistive load, this Ref: http://www.visionics.a.se/html/curriculu...fier1.html you would think that the max would be 81mA as that is the efficiency. But just to confuse things Hammond would have you believe the DC can be 127 mA in this configuration.
I'm expecting this to be a trick question as you must have looked at the chart
Gary
Gary
. Post-repair, during a 'soak-test' with the sleeve cover removed, I noticed how hot the mains transformer got: all the indications were (and are) that that temperature is normal: no malfunctions were detected later when the case was re-fitted and a much longer 'soak-test' was run. However, what was even more alarming was just how hot some of the encapsulated bridge rectifiers got (they're not mounted on heat-sinks). For one of those you wouldn't leave your finger on it for too long! Again, that appears to be 'normal'
. I did some research into this (mainly via the Internet) and it does seem that the PSU section of the 475 is the really weak area in the design: typically the PSU filter capacitors lose capacitance. Now considering the age of the 475, that is fair enough: electrolytics deteriorate with age (especially when fitted next to things that get really hot) - so we replace them: and that's the problem with the 475: component replacement and general maintenance can be extremely difficult. The saving grace with the 475, of course, is that when it is set up, calibrated and working properly, it is a very good 'scope. Just a shame that Tek. crammed a quart into a pint pot - even though a (small) fan is fitted (which runs fairly slowly), this scope still runs remarkably warm - thus shortening component life.
