24-10-2012, 06:48 PM
(24-10-2012, 06:19 PM)Joe Wrote: To travel the 180° from maximum to minimum frequency needs 75 turns of the tuning handle.
Here's a shot of the top of the chassis:-
The odd thing is that there are quite obviously six valves yet the component list only mentions four. There are also far more capacitors than are detailed. Luckily I'm only replacing like with like and can read the values off the old ones.
- Joe
That's not a bad reduction ratio, three of the valves should be of the same type, EF39's maybe.
According to the specs SW covers approx 6 to 23 megs so as a rough guess approx 225 kcs per knob revolution, should be able to BFO that with a steady hand.
