01-05-2012, 05:23 PM
Tony,
I think you've got a couple of typos in there re Resistor numbers - Rs about face
R12 varies the bias on V1 Grid, so V1 is at Maximum gain when R12 is at Minimum value - shorted. It does actually work as far as that goes - the bias on V1 varies nicely, and stays at a low value after about 90 deg. rotation. My book of notes is in the garage so I can't tell you the actual value. The problems start with further rotation. The volume actually drops and there is some evidence of oscillation. The bias on V1 however remains constant. Attached is the Pye description of it.
C18 tests fine, both value and ESR, and substitution makes no difference. The voltages on V1 are also fine and the Rs and Cs measure OK. So that leaves C20 as suspect. I'm not sure in what way it might be faulty. I'm reluctant to take it to bits unless I have to. If I could buy/beg/borrow/steal a suitable substitute I'd tack it in and see what happens.
Alan
Alan
