02-02-2012, 06:17 PM
Thanks, David!
Interesting document, and clarifies a point that I found was surprisingly hard to be sure about: the 2.5 metre distance is when facing the boundary.
My flue is quite close to the party wall - it's in an upstairs bedroom at the rear of the house, and the flue points down the garden. See position C in the document - only it's upstairs. Relative to opening windows, it's more than far enough away from openings...
If I'd put it on a side wall at the rear, then we would be in trouble because the passageway down the side of the rear extension is only 2 metres wide. Here, the flue would have been pointing sideways. That said, the neighbours house is a mirror image, so there would have been 4 metres between the structures, so technically there would have been no risk of condensation forming on the neighbouring property.
When we first moved in, our neighbour complained (amongst other things) about the flue position - despite the fact it was decided some 8 years previously by a previous but one owner. In the intervening years, she's been completely unreasonable with us about absolutely everything, so I felt under no compunction to move the flue to the roof or similar - and as the current position meets the regs, I've left it where it is. Had she been nicer, I would have moved it as a courtesy. Of course, there's no point trying to explain this to her...
Meanwhile, at the front of the house, the other neighbours have a boiler flue even closer to us as their boiler is installed on the party wall in the upstairs front bedroom (which is actually a kitchen because the house has been divided into flats). The flue is within inches of the boundary, but faces forwards again, so no problem...
Actually, our new boiler hardly "plumes" compared to the old one because it's running with a much lower return temperature, meaning that much more water vapour is being extracted by the condensation process. Another reason to consider Weather Compensation! Another neighbour, with a smaller house, has a boiler that looks like a steam locomotive - I dread to think how that system is working!
Cheers,
Mark
Cheers,
Mark
