18-06-2013, 09:11 AM
Hi,
Well spotted Refugee and you are correct; yes plastic gears throughout.
I've actually been running this lathe previously with 60 thou cuts using the plastic gears without problems other than the electrics but like you I too have reservations about their longevity?
If the plastic gears fail then I'm just the guy to upgrade because a few years ago I came up with a quick method of cutting cast iron gears using a lathe so this isn't going to worry me unduly.
I do need to get one of my Myford lathes restored because I feel lost without a decent sized lathe; I keep resisting the temptation to buy another Colchester Triumph and a car upgrade next year rules this out due to the new car being bigger than our current car. If I had a huge warehouse I would still run out of space.
I've just spent an hour browsing the web for inspiration as my thoughts are turning to replacing our old double glazed windows and doors with home made solid oak items; now that would be a nice project because I have the kit to make these. One site recommends the use of green oak which is considerably cheaper but I'm concerned about splitting and cracking so more research is needed. I never let up but I'm never bored.
Kind regards, Col.
Kind regards, Col.
