28-06-2020, 03:14 PM
I doubt that the transformer is the issue.
Check the continuity of the ground wire from the 50uF caps.
The heaters centre tap is white according to post #91
It might not be anything to do with the work you have done, for example a pin in one the valve sockets might not be making a good connection.
Eddie
Eddie
