06-04-2014, 11:30 AM
(This post was last modified: 06-04-2014, 11:53 AM by Radio Fixer.)
As Lawrence says the 3000 Ohm coil is typical for a speaker with a shunt field. I rewound one once that was 4000 and it took 4.5 miles of wire and in excess of 40,000 turns!
These were not used as smoothing chokes and as you can see they got away without this by large electrolytics.
The bias res. has 7.8V across it which is 31mA so the drop across the field is 93V giving roughly 100V at the rectifier cathodes.
Not sure where the 300 field comes in but if you have that then the speaker has been replaced and it would be correct to wire it in series with the HT feed. It would be wired between the two +ve ends of C24 if they are brought out separately. This way it would contribute a small amount of extra HT smoothing. It would drop maybe 15V but the HT will rise a little anyway without the shunt field load. However the bias for the output valve would now be incorrect and more changes would be needed. Two ways to do that which we can go into if this is how things are.
Gary
Gary
