14-08-2023, 10:03 PM
I was fixing a CB and it had no RX audio on speaker, but speaker was OK. Audio out OK on amp. Mysteriously the earthy end of speaker went to mic socket, but the mic plug had no wire on that pin!
So went and found schematic for mic for that actual model and found the PTT switch earths speaker on RX and earths TX to on when pressed. Odd. But I left it as it was and wired the mic to suit. It did have a four core cable, but no connection on the normally closed on PTT and none on plug. Both ends 4th wire cut flush. Can't have been original mic?
