22-10-2022, 06:48 AM
They look similar to those used on radiograms and some radio's as Ed says, failing that you could use a different bank of ganged SW's but locating them might be tricky and screw up the originality but your onto a real loser if you try and repair them I think. I've tried to repair similar SW's with zero success, springs leap into space never to be seen again, though that can be solved by opening them inside a plaggy bag & they're very fiddly. In which case see if you can find a scrap Bush or radiogram and then swop the whole SW bank.
Andy.
Andy.
