17-02-2011, 06:38 PM
Here is something I repaired a few months ago. A direct drive prewar turntable, that plugs into the gram sockets of your valve radio. Unfortunately the pick up coil had gone open circuit so it had to be rewound, rewire the mains and change the 0.7uf caps in the motor, change the screened wire in the Marconiphone arm and away you go!
I must admit it does sound nice.
Just have to decide if the cabinet needs to be refinished.
What do you lot think?
cheers Mark
cheers Mark
Keep on Fiddling!
