06-08-2020, 04:12 PM
My R700 is fine. Much better RF on AM and FM than the R600. Though my Hacker RP18 and RP25a are both better. The reduced VHF coverage isn't an issue as: (1) I don't use them much, (2) There aren't any stations here above 101 MHz that I listen to. RTE1, 2FM, Lyric, RnaG, Clare and Limerick are all 89.4 to 99 MHz.
I think I have two other Roberts: A Vidor styled battery valve model that maybe is octal and the not actually Roberts rebadged Sangean Radio-Cassette with a BFO. I'm not planning on more. The R700 and R600 were nostalgia, the other two were bargains. I'm really concentrating on other things, I have loads of sets sitting here for years to sort.
I've encountered plenty of whiskers and this fault wasn't like any. It wasn't affected by tapping. Also I never saw one exhibit the operating profile.
The fact that it only happened if the set was unused, initial perfect audio, sudden silence and then after a minute fading to normal like a valve set warming and thereafter absolutely fine for hours, and even if off for maybe 10 minutes. But leave it off an hour and the cycle repeated. I'll see what inside the AC128 eventually. Certainly two capacitors were marginal, the o/p speaker decoupling being the worst. It's in a feedback path too.
