06-07-2020, 09:35 PM
Just add a second diode, ground is anode, cathode to existing anode.
Or try it with capacitor direct to g1 with a 10M or 18M grid leak.
You can't sensibly have a wide band (entire MW) high impedance RF transformer. It won't work if a 10 mH choke from 0V to diode input doesn't work.
Alternative DC path solution: Wire like a valve detector. Diode across the 18M or 10M grid leak, fed with capacitor from RF amp, thus cathode to 0V. Also try it the "wrong" way round, where it drives g1 positive instead of negative.
